spray hardwall
Dansouthcoast84
This all confirms what I said earlier about the need for a decent comprehensive booklet.
When I first bought my Ritmo how the hell was I supposed to know that different materials need different R&S's or which ones?
The PFT instructions might as well have been written in Greek!
close they are in german....
theclemo
A clamp r@s should do all on the ritmo.
Vincey
Tbh this is why I like forum threads I’m not the brightest spark but do and have read a lot of the machine threads , they are always there to check up on things a lot of help and advice is here, even when I’ve asked daft questions someone has always gave an answer or suggestions, really does help
Also when reading old old threads I realised I’m not the only thick idiot on here when using machine and most are in same boat.
vfr12
MOTORC*NT
most 3 phase machine have built in gennys. try a 20 kva see if it makes any difference
If you mean the 230 v socket underneath , yes I do have it and when using the machine in 3ph I just plug in the water pump to the machine and 3ph from the gene to the machine. Surely the Germans had the same idea when designed the machine . We should have all the info given to us when buying any type of machine , new or used,and not just how to turn it on and spray. That’s far from what we need in the first days with the new machine. I have done some research now, since you didn’t say what r&s you are using when in 3ph and found out that the recommendation is slimline for 230 and d6-3 twister when in 3ph, exactly what I was suggesting,so there is no one universal r&s for the machines , you have to chose and select based on what material , distance and power you are using. That’s new to me tbh and I have used ritmo before I got my own and we didn’t had any problems with any material or the kind of bs, hence I went for ritmo and g4 in one.
My research also says I shouldn’t had have problem running the water pump and machine from the gene in 230 , but for some reasons I can’t which is telling me Ryan might have the edge here .
vfr12
MOTORC*NT
And while we are on here.... I need a light weight shaft for XL @PFTwales and @Plasterers1StopShop if Any of you can give me a price and delivery time that will be great. Any hint on what r&s I should use with bauwer light will be much appreciated too. I don’t want to end up with disaster day and look like a proper c**t , won’t be the first time tho :rolleyes:
PFTwales
you should have been told during your training session.
PFTwales
r u using the xl in single or 3phase mode
essexandy
The Lake Governor
If someone could just come forward and say ' right, we've got this machine, if you put this part on it and set your water to roughly ### it'll fire Hardwall on like you won't believe. If you take ## off and put ## on and set your water to roughly ###, it'll wack Monorex on at 10 ltr. a minute, all you'll need is ## transformers or ## generator', they'd clean up.
We bought our machine and generator, but then found out we'd need two new transformers to run of the mains, oh and "don't plug both transformers into ###".
You need to be able to plug and play from day one.
And breathe, rant over.
vfr12
MOTORC*NT
I someone could just come forward and say ' right, we've got this machine, if you put this part on it and set your water to roughly ### it'll fire Hardwall on like you won't believe. If you take ## off and put ## on and set your water to roughly ###, it'll wack Monorex on at 10 ltr. a minute, all you'll need is ## transformers or ## generator', they'd clean up.
Exactly my frustration mate, and maybe I wouldn’t be so disappointed if I didn’t had to redo 40m2 of mono cos the f**k**g r&s wasn’t up to it. How the f**k should I know that . FFS.
Rant not over :mad:
Far from over :D
essexandy
The Lake Governor
Rant not over :mad:
Far from over :D
Mate I've hand applied whole (big) houses with Hardwall and many, many metres of render because I can't be doing with problems on every job.
Years ago I spent £2000 on a road towable cement mixer and it has earned its money so many times over with zero hassle. I so, so wish the same could be said for the Ritmo.
Plasterers1StopShop
Can easily do this for you with the M200 and M330 mate
We sell packages and list add ons for various applications
vfr12
MOTORC*NT
Ha ,funny you should say that, I got my eyes on forced action mixer at the moment
MikeAtthis
I don’t know just stick with the hard r/s and ask questions if you venture in to something else seem like a no brainer to me
theclemo
Tbf id f**k all problems with the ritmo l. I have the generator to run it and the pump. And have a water butt. I always have 2 or 3 r@s with me. I use just the one for hardwall won't put render in that one. But electric machines are temperamental
theclemo
The man says different. I wonder why it won’t work on XL?
I don't know lol. Get a diesel. That's my plan have a ritmo and diesel. c**t let me down on a diesel a few weeks ago. Told me he would sell it to me. Then he pulled out the c**t of a c**t.
owls
If there wasn't problems with the ritmo, I'd miss not be able to phone up @PFTwales, but I secretly think he gets off on the power of it all.
vfr12
MOTORC*NT
I have a big diesel for you and you already know you love her
His love about carbon goes back to his childhood. Once black, forever black :D
owls
He sold me a gold plated stator recently, he claimed it would help us spray monorex more effectively and help us pull more birds... it didn't but he sounded knowledgable about it.
