Yes it is quick and effective, I know a few lads who have had steel clad workshops done to stop condensation and keep the heat in. It is not cheap mind!!!
I've seen it done it is very good and very quick but it's expensive the customer told me, so not sure if it's expensive material and set up, but many times thought about doing it
I was offered the gear for doing it at a reduced price last month and decided against it. If you google it you can get kits which range from 50m2 up over. The fumes from it are toxic and you need a very good mask
Very popular in USA and Canada where R values/rules are higher than here.
Insulation is the single most effective use of money to upgrade any home. Easy to do and instantly effective.
Yeah that's the one
Been checking it out on google there is a few bad reports about the smell and quite toxic.
But there is plenty of good reviews aswell
Yeah that's the one
