ggb plasterers
Been thinking of buying a speedskim for ceiling work to save my old bones but what blade is best the blue or grey and what's the difference?
What's the differenceNeither get an eze spat instead![]()
Cheers fellaSearch on the posts mate loads of info I've never used the eze but I got the speedskim blue blade helps out massively n used near to the finish of the set
I'm fed up with the eze pics too! Can we have some kinky ones of Mrs marshy, its been a while she's beenThe eze spat is a brilliant piece of kit I'm fed up of posting pics proving it and some are in recent threads but like anything it's all personal choice so try everything first if I were you ?
Eze is top class, use the speed skim to flatten if it takes your fancy
Here you go hail hail
Link Removed
Hey guys I bought speedskim a few weeks back, I bought the blue blade (st) and also the pink blade (sf) with the steel tip and what I am finding is that the blue blade is brilliant for flatting but the pink one is not great at all for finishing. My question to ye guys is are my better off buying the eze spat for finishing and polishing afterwards?
Can you use them on 2 coat work and not have to sponge itNeither get an eze spat instead![]()
Sponge???? What the f**k is that? ? I only sponge plain rub render or Mp75 one coatCan you use them on 2 coat work and not have to sponge it
Tidy I'll be looking at the eze spat then ,any recommendations on size and where to buy ?Sponge???? What the f**k is that? ? I only sponge plain rub render or Mp75 one coat
Our good friend @Plasterers1StopShop will sort you out I have the 1m and 600cm and brilliant you would not regret it pal please don't sponge stuff lolTidy I'll be looking at the eze spat then ,any recommendations on size and where to buy ?
Never had or will I swear on my old marshaltowns lifeOur good friend @Plasterers1StopShop will sort you out I have the 1m and 600cm and brilliant you would not regret it pal please don't sponge stuff lol
Na not us chuckI've noticed this a few times on here but am I reading it right. Are you nutcases across the big pond sponging up skim?
Na not us chuck
Can u finish with ez spat straight away or does it need breaking in? We've got speedskim blue blade which is good for flattening and we've got the pink blade which is s**t leaves it all streaky and looks rough as so stopped using a while back massive waste of money in my opinion..I have the 1m and the 600 which is all you need anything over 1.2m I think would be too clumsy and think you'd struggle to apply even pressure over the length? Am sure some would disagree but again one thing works for one but not the other?
A bit of steel wool or glide it over a previous skimmed wall thats a day or do old. But yes you can finish with them but i only do on new plasterboarded ceilings and not on reskims where the existing ceiling is pissed as it doesnt work as well and yoi will need to finish with a trowel. Obviously you always need to trowel your angles anyway. My method is to keep cross troweling with the eze spat on ceilings and big walls youmay need atouch of water on last couple to stop any dragging/chattering etcCan u finish with ez spat straight away or does it need breaking in? We've got speedskim blue blade which is good for flattening and we've got the pink blade which is s**t leaves it all streaky and looks rough as so stopped using a while back massive waste of money in my opinion..
Shudnt even sell them pink blade speedskims there a con..we usually just flatten with blue blade speed skim then do the rest with Refina s*p*r*lex havnt got a nela the 1 stop plasterers shop have never got any big 1s in always out of stock as wudnt mind getting 1The pink blade is the biggest waste of money that I have in the back of my van. What I do use is what I call the speela which is the speedskim blue blade and nela trowel, I flatten with the blue blade then the final wet trowel and polish I use my nela, perfect finish every time happy days
Cheers marshy mite buy 1 2day..just wanted to double check before part ways with cash as them pink blade speedskims have put me off a bit as theres no way u can finish a wall with them and there meant to be finishing speedskims b*ll***s there r..A bit of steel wool or glide it over a previous skimmed wall thats a day or do old. But yes you can finish with them but i only do on new plasterboarded ceilings and not on reskims where the existing ceiling is pissed as it doesnt work as well and yoi will need to finish with a trowel. Obviously you always need to trowel your angles anyway. My method is to keep cross troweling with the eze spat on ceilings and big walls youmay need atouch of water on last couple to stop any dragging/chattering etc
No probs and glad to help. Ifyou just want one to do everything? The 800 probably best all rounder? Tobe honest i use my 600 most of the time and onlybother with my 1m one on big stuff. Id be lost without them now they make life so much easier especially ceilings.Cheers marshy mite buy 1 2day..just wanted to double check before part ways with cash as them pink blade speedskims have put me off a bit as theres no way u can finish a wall with them and there meant to be finishing speedskims b*ll***s there r..
