kirk johnstone
ALRIGHT LADS AV GOT A BIG JOB COMING OFF IN FEB ITS A SMOOTH RENDER AN THERE IS ABOUT 1000 SQUARE METERS IN IT AN THEY ARE GUNA SUPLY. HOW MUCH DO YOU RECON I SHOULD CHARGE PER METER ???
church said:need more information to price it correctly .Is it new work or rendering over old work ? Is it two coat work or OCR ,what building is it ? Is it for a builder or private work ? all makes a difference.
he wants a scratch coat then a screed tren a finishing coat so that in is perfect mate.steve_cov_spread said:why is it 3 coat work then?
Pug said:ought to be able to get it bang on in 2
2 coats of 9mm mate, too tight and the blocks will grin through looks crapoasis said:while were on the smooth render, like i said before I'm goin to be doing my dads blockwork shed, bead up and 2 coat render, he told me that 10mil will be fine! I'm guessing he meens bring the beads in nice and tight, i said some people on here say 18 mil ect he said crap just do 10 will be fine?? I'm lost i no he must be wrong as he said 10mil quietly!
napper83 said:scratch it an top it simple really
napper83 said:if its gotta be bang on rule your scratch aswell and get another spread with you or try and talk them in to using an ocr
bout £12 a mtr s&c an £10 ocr
btw my brother said your a chancer ;D
essexandy said:Surely if you've done enough rendering to do a "spot on job" you should also know how much you need to charge per m2 for two coat, three coat or whatever.
kirk johnstone said:essexandy said:Surely if you've done enough rendering to do a "spot on job" you should also know how much you need to charge per m2 for two coat, three coat or whatever.
i normaly do one of houses to a mint standard and charge about £1200 per side for an average 3 bed cemi, but this is a mansion an av never priced things by the meter before so i just want to get a rough idea of what everyone else charges so that am not way out on the price, pluss am pricin off a drawin so i cant even look at the job to weigh it up properly.
essexandy said:kirk johnstone said:essexandy said:Surely if you've done enough rendering to do a "spot on job" you should also know how much you need to charge per m2 for two coat, three coat or whatever.
i know mate but thats a high price isnt it, its ok when you price one off houses on a recomendation but am talkin about over 1000 meters. i dont think am goin to be the onley one pricing this so if i went off my rough estimate way like i normaly do i might £7000 more than the going rate, thats why i just want sumone to tell me wot the going rate for 3 coat work is. d you know wot i mean bud
Well I would guess that each side of a three bed semi would be about thirty five m2 tops, so if you normally charge £1200 per side you are getting about £34 per m2.
kirk johnstone said:napper83 said:scratch it an top it simple really
the walls are about 100 meters long an they dont want to look down then and see waves, its gota be spot on mate, dont wana take any chances. you know what builders are like when it comes to pickin up the cash of em :
any sugestions of a price per meter?
flynnyman said:kirk johnstone said:napper83 said:scratch it an top it simple really
100m long? have you priced in expansion joints?
kirk johnstone said:flynnyman said:kirk johnstone said:napper83 said:scratch it an top it simple really
no mate av never done an external job this size before, what do i do for them an how much do i charge extra for doing it?
