does anyone know the most suitable slip joint to use for timber frame aquapanel system with thin coat? the wemico site is showing 2 different profiles. thanks
www.wemico.com
Render Only Compression Joint | Wemico
Wemico render only compression joint for thin coat render. Ideally suited to timber framed buildings. The aluminium base section is supplied pre-coated white.
www.wemico.com
