Skim over wood
Youn3d
Hi everybody.
As you can see on the photo, I would like to skim a small part of wall over 2 doors but there is a bit of door frame showing in the middle. Ideally I would like to have the same finish between the 2 doors too but I guess you can't skim on wood. Any suggestions how to make the transition?
Thanks.
MakeItSmooth
I'd be tempted to try a lazy shortcut with that (nothing ventured, nothing gained...), by papering the bit between the architrave (using PVA), leaving it overnight, and then emulsioning it.
If it wrinkles, then you've only lost a few minutes labour, trying it.
