I’d give it a couple of coats because as said, it’ll suck like a Thai hooker
Secrets out Lurpak.................Cheers lads why dont they fekin tell you this on the bucket of filler? Another job to do.Suck a golf ball through a garden hose some of them lady bois
If the joints have already been taped & filled why are skimming the whole wall?Does Knauf Joint Filler and tape need unibond applied to it before the job/boards are skimmed over?
Because I dont want to sand the joints and screw heads down. I would have to apply a second amount of filler to screwheads and sand all 180 m2. The time would be huge so to speed things along I thought I would ask for a skim price.If the joints have already been taped & filled why are skimming the whole wall?
They probably still get more skim than your boardsTape and pointers are faster and earn more than spreads on sites
I havent but you would still have to sand it slightly before painting and its approx 60 boards.Why put on more than you need to
Cheers for this. i had decided to spray water on joints filler before plasterer arrives. I did ask Knauf last week..........heard nowt..........must still be on hols?I’ve been skimming a room today I taped before Christmas, no need to pva doesn’t suck in hardly at all but that’s using the bg gyproc joint filler. Haven’t used knauf.
Suck the chrome off a tow barSuck a golf ball through a garden hose some of them lady bois
I have written earlier regards this but here you go.
180m2 of boards which will have to be filled again (2nd time - screws) then all sanded down (180m2 - 60+ boards and lots of internal corners) ............and no doubt touched up in places with filler. Mess = Unbelievable. Price for skimming while I am able to do other work.................suits me just fine.
Probably Steve after all I did it and I am shite at everything...................What are you good at besides disagreeing or finding fault with everything I say or do?Must be very bad boarding.
I didn't know you'd done it. Boards shouldn't need filler.
I'm good at lots of things. Boarding is one of them.
If boards dont need filler what do you put on joints?
You mean scrim tape then fill the recess with skim?
8'x4' or 2400x1200 with recess on long side edges. No recess on long end edges of boards.
That is correct and damaged edge boards which mysteriously find their way into the middle of the bale..........so good job they invented filler?If yo have bevelled edge plasterboard, then it has a drylining side which is recessed and a skimming side which isn't.
The two don't match up particularly well. I did a job a couple of years ago where the guy had filled flush board joints...it was a fuckign nightmare - he'd totally confused drylining and skimming, so now I have to plaster his BFO lumpy joints that he's filled with scrimtape so it couldn't even be sanded properly.
