skim ceiling
GPA
Hi Guys, I need some advice, i have a ceiling to skim that has been over boarded but the walls are being left.... so my question is, if im scrimming the ceiling edge im going to have scrim tape showing on the wall edge. shes also stated that she doesnt want coving. any ideas? thanks
Dropsalot
You can only put the scrim around the edge just touching the walls not a 90deg scrim, if there are gaps at the wall, fill them first, then scrim.
D
Deleted member 29624
Guest
Run scrim around the edge but warn a possibility it could crack, if it does a tube od decorators caulk is 83p in b and q(y)
gps
Scrim up to the edge and then after skimming caulk around the edge, it's something I've always done.
malc
TPF Special Forces
scrim the joint with half on the wall. when the ceiling has set blend the scrim on the walls with easy fill.
Pagey
Why not just scrim half half then once plastered cut the bit off that's on the wall
D
Guest
Why not just run a bead of caulk around the edge, bugger messing about feathering easi fill over scrim tape, would imagine that looks s**t anyway
I have never used scrim then chopped it off... if the walls ain't getting plastered the the ceiling get skimmed and that's it.. if it cracks... which it probably won't then paint will get it and if they are persistent a bit of caulk will do
Pagey
Same here
I ain't gonna fanny around easi filling down a wall then waiting for it to dry then sand I just scrim half and half on ceiling line once skimmed say 3-5mm that will hold it in place and be tighter than if you only tape on board then just cut it with a Stanley when dry or tell them how to do it or tell the painter job done never had a call back on it so if any have cracked I don't know about it
uni-king
Adds another day on Job fcking about doing it that way lol..f**k that
Pagey
I'm sure in the cupboard ceilings you do it ain't a problem lol
Richard paul
Cracks happen if plaster is unsupported. so I put tape upto the walls making sure it's covering any board edges. shouldn't be a problem. in fact I do this upto windows and doors also exposed beams etc .. works a treat and always explain if cracking should happen then decoraters mate will sort if needed.
