Skim bead cracked
Jimbob87
What's the best way around this? Should I pull the bead off and start again? Or just go over it with some more finish?
Should alway scrim them on re-skims and get the angle right so it isn’t on so thin on bead. That one of them 1 coat beads? Lol
It was only plastered 1 week ago. I also put the skimming on thick around the window. Had to bring it out more with skim around the top part of the window.
I think it's the grease on the beads that makes the plaster go like that....
When I have a had a bead crack I just pull it off and get a new one then use filler and patch it in
Yeah someone said that before, I didn’t previously know that. This definitely looks like moisture though.
