Shower wall prep problems
Rich H
HI All
Hope someone can help on this, we moved into a new property just over 4 years ago and within a month had water coming through the ceiling from the en-suite. (quality workmanship!) Various fixes occurred and it looks like the one put in place just stemmed the fault as we have the same issue.
The bottom of the water resistant plasterboard was very wet behind the first row of tiles tiles and the paper ripped, damaged. I have removed the tiles and are going to use shower panels to seal the shower.
Questions are
Do i need to replace water damaged board areas ? or options to seal and re-
plaster ready to fix panels to wall
Can i fill in holes, sand old adhesive left and reskim ? The brown areas are water stains on the walls and brush off - plaster does seem softer here
Any advice grateful
cheers
Rich H
why the f**k are MR boards getting skimmed?
they are not made to be skimmed onto, you take away the whole point of them being moisture resistant if you do, they are designed to be tiled straight onto like tile backers and aqua panels.
wtf goes off on these new builds nowadays does anyone know what the fk they are doing?
on new builds, you find the most un practicable person that you can find and put them in charge.
HI All
Questions are
Do i need to replace water damaged board areas ? or options to seal and re-View attachment 69774View attachment 69775plaster ready to fix panels to wall
Any advice grateful
cheers
Rich H
Replace with wedi board
HI All
Questions are
Can i fill in holes, sand old adhesive left and reskim ? The brown areas are water stains on the walls and brush off - plaster does seem softer here bathroom remodeling new york city
Any advice grateful
cheers
Rich H
I think you know that the shower panel idea is again only likely to stem the problem; leaving the damaged "water resistant" plaster board area could lead to mold and smells; for the water to have gotten behind the tiles and down to the next floor the tray has not been fitted correctly and I suspect more than likely there is a drain plumbing issue for water to appear on the below ceiling.
I would recommend, tray removal, board replacement as for sure after 4 years there could be rot underneath.
