What you mean? A stop bead next too the window ?
I've never ever done that in my life and never even seen it done in any house in most parts of the country I've been .
ive always and always seen it skimmed up to the window reveal ,unless I'm reading you wrong mr John :RpS_biggrin:
That explains it,the southern pansys probably can't get em straight so use a stop bead:-0It's a southern thing bud!
WeirdosPast few extensions we've done architect has spec'd stop beads in every internal corner.
quite a regular spec. usually on commercial and military work.
Done a fair bit of commercial this past few years,never heard of it.quite a regular spec. usually on commercial and military work.
its work as per spec, but I have used them for 15 plus years, back when money was good...Lol to be fair it does look better and the shadow beads look better again but not for most domestics as to time consuming.. Plus I wouldn't know where to source the shadow beads anyways
Malc is that a recent thing with the military spec ??
that sounds right. to give the walls a floating on air look.
we have had to fill the lot in on a hosipital job as they create a dust trap!
they are building a new garrison at colchester, it will be in the spec on that contract. that is where we trial a lot of different ideas. you must follow the spec, or you will end up in big trouble. the new garrison is the largest building site in europe.
we have the 17th defence mobile, half in colchester, the other half at raf wattersham in suffolk, the gurkers are also in town
Is the garrison not finished yet malc? When i was last in colly on 2005 they were just starting. Im back down there next month for a little reunion so i will have a butchers................:RpS_thumbup:. The gurkas has a company attached to 3 para a few year back...........nobodys fu@ks with the lads
Funnily enough spunky I had to on a job last week, it was a really thin window reveal so would of had to cut the beat down anyhow. So used stop beads on them,can't really tell from the photo but they were only about 1",just on the extensionDo any of you stop bead externall reveals
Is a shadow bead like a stop bead but with a 10mm add on ad the side? We did a job for a couple of architects and they had that everywhere. No skirts. No architrave. Cut the board 10mm short and it fits in flush?
feature instead of arkithraves or skirtings, architects love them, 'clean lines 'Do they serve a purpose or is it just a feature?
