If im skimming ceilings and studs first ill stick them with a bit of left over skim.
In sand and cement is my way..External render !!!!!!
don't use dab it'll come back and bite you, I learnt the hard way, I normally use hp 12
I use galvanised nails - not sure dab are poor practice?
I'm going to have to stop coming on this forum, I find myself giving people sarcastic replies more and more every day
Hi guys
what do material do you use when sticking beads on new block work and uneven stone backgrounds .
galv nails rust very poor practiceI use galvanised nails - not sure dab are poor practice?
I was doing an internal job for a customer & the bricky outside was putting 2 small windows in the main wall, anyway after they was in I saw him dab the galvanised beads on with out of date multi, then rendered it with one coat of render using building sand lol. :RpS_biggrin:
Then he tyroleaned it the next morning & got it all over the glass & wiped it with a dry old rag after leaving most of it on the glass & he didn't even try to blend it in to existing wall :RpS_unsure:
The same bricky I heard put some coving up on a job with drywall addy which is fine but it was on silk emulsion in a kitchen & it all came down :RpS_laugh:
