Yep , fill the tank with water you will have to hold it down with digger to be sure it doesn't start risingAnyone experienced put in a septic tank in with high water table, the hole has got to be 12 ft water table is at 4 ft,
I thought that I would need to fill it with water,Yep , fill the tank with water you will have to hold it down with digger to be sure it doesn't start rising
Yes push it out the top, dig a mall run off Chanel so it goes where you wantI thought that I would need to fill it with water,
Will the concrete pouring just replace the water in the hole?
Cheers mateYes push it out the top, dig a mall run off Chanel so it goes where you want
Normally you fill the tank as you go to help equalise the pressure on wall anyway , if you're pouring slow you may get away with pump to get water in hole to drain , I left water in tank for few days before pump outYes push it out the top, dig a mall run off Chanel so it goes where you want
I can see things going f****** pear-shapedNormally you fill the tank as you go to help equalise the pressure on wall anyway , if you're pouring slow you may get away with pump to get water in hole to drain , I left water in tank for few days before pump out
Pour slowly , digger forks on top to stop it floating, take video for Friday night if it goes wrong lolI can see things going f****** pear-shaped
Draw me one of your diagrams and everything will go sweetPour slowly , digger forks on top to stop it floating, take video for Friday night if it goes wrong lol
I'm not f****** joking I'm shiting myself literally with no septic tank
I'm only a rough ass renderer something's bound to go wrong View attachment 42353
Top man!Lol
Pour in 8" muck
Plonk tank in the hole ,
Fill it with water until it settles nice and straight and positioned central
Pieces of wood under forks and press gently to stop it floating
Add an extra ft of water in the tank above the water level on the outside and maintain it as you pour
Forks will stop it from floating , just pour evenly around the tank as best you can , use a length of 4x2 to check depth all around , once your past half way you don't have to be so fussy ,
Just pump out water as you fill tankTop man!
I think it will be the first bed of concrete that will be the problem as the hole will fill up so quick
if u have digger then put a land drain in on lowest point to move water on /don't empty tank again once filled with water through a dead sheep or similar in to start the process workingTop man!
What about about a dead labourerif u have digger then put a land drain in on lowest point to move water on /don't empty tank again once filled with water through a dead sheep or similar in to start the process working
Cheers mate I've been told chukka dead hen in to start the processif u have digger then put a land drain in on lowest point to move water on /don't empty tank again once filled with water through a dead sheep or similar in to start the process working
even the wife if no chickens lolCheers mate I've been told chukka dead hen in to start the process
Not you by any chance mate
Is that made of fibreglass? how much are they?I'm not f****** joking I'm shiting myself literally with no septic tank
Yes mate £700 TravisIs that made of fibreglass? how much are they?
I could have made you one, new idea on its way.Yes mate £700 Travis
It would leak I know what your like with holesI could have made you one, new idea on its way.
tapit tank another load of s**t coming to your screens shortly DONT MISS OUT ON THIS GREAT DEALI could have made you one, new idea on its way.
and loose all the knowledge you come on here for !Could throw an old hobo in to start it off.
who is the second one not u lollooks like just the two friends then hobo!
away and mix your fibreglass and come back when u need to pick my brain when it goes tapitupJust groove and cockney, a rum do indeed.
i'm a dab hand with a roller and some woven matting and i don't drink the acetone.away and mix your fibreglass and come back when u need to pick my brain when it goes tapitup
