Scraped render
hack off and redo
Scraped render
Whatever you’ve rubbed up scratch it again asap so the customer thinks it ain’t being top coated yet bosh
To late now started hacking it off it was probably just about visible size of an apple it was actually the first pressed I accidentally rubbed back to so it was all same colour .
if it was that small, you should have just cut a square/rectangular shape around it, remove it all the way back and patch it up. Once scrapped back the only visible marks would have been the little edges of your cuts, which from a distance are not even noticeable. But then again, if it's the front of the house is better to just re-do it....
