Sbr parex microgobetis?
If you're using krend either eml and hp12 or scabble it off and use hpx never used microgebetis rx7s a sealer you wont get a key off it, if anything use microgob if the paints sound and you want to chance it
Krend used to spec r7 to use on smooth concrete so i dont think it is just a sealer spunky , if you put the first coat of krend into it whilst it is still wet it all becomes one on the wall a bit like putting grit into it
