s&c ratio
kgreigh
Eveningall,i have a 3m x 3m area to render with s&c then use a tuck pointer/small tool to draw a flemish bond brick pattern in the top coat to later be painted to match the rest of the building whitch is painted bricks.
The area to be rendered is made up of 1m x 3m thermolite blocks then 1m x 3m of red reclaimed bricks then finaly 1m x 3m strip of concrete blocks (measurements are rough)
The question is what s&c ratio would everyone use?would you mesh it all? etc
johniosaif
Scratch coat 5/1 over all,probably best to render grit it all the day before or sbr scud,
fibres of two handfuls per mix rather than mesh
floating coat a week later 6/1/1 sand cement lime
kgreigh
Thanks john,I'll be using an sbr scud and as carlos mentioned eml however initially i only thaught to use it where the different materials join.
superspread
And fix building paper or if u haven't got any cut up a plastic rubbish bag into 4inch strips and put over the two substrates first before eml-img
kgreigh
Not completely sure that I wouldnt, I don't normally ,but like all us oldies I decide each job as it goes. I understand while Carlos is saying it though..
I think ill give the fibres a go but still eml the joins,it wont hurt to
malc
TPF Special Forces
with those three different suctions and almost certain cracking. i would cover the whole area with building paper and then rib lath then render.
