I'm more surprised you used weber also!!Used Weber Pral.m today at 120 water. The material started to spray stiff and the float was down th 75. Turned it back up to 120 and half hour later the float is back down to 75. Any idea's why the water is going down?
Water pump blew a fuse in the plug as well.
Solenoid?I'm more surprised you used weber also!!
I got forty out of my last oneFk me 36 pallets!! Fair play
just cannot beat a bit of Doctor in the mix !lolHurry up....................Nice one John
i take off the water feed to the hopper put a hose on there and undo the drain on the filter to clean it out dont know if your supposed toI had this problem rigsby when I was spraying hard wall,the water was just slowly dropping,it turned out to Be the main water filter under the bottom of the machine.
The one were you need the gay spanner to undo it,took it out and it was blocked for sure.
I have also had my tap replaced as well,this was sticking the water would drop so I go to adjust it and nothing would happen the float would not go up or down, then suddenly it would adjust,so just replaced it.
Same here!!i take off the water feed to the hopper put a hose on there and undo the drain on the filter to clean it out dont know if your supposed to
