Renovating an old stone cottage
ajn9000
Any thoughts on this plan for an old stone (slate & lime mortar) - the back wall is 600mm below ground level - walls need to breath and condensation minimised ...
Walls preped back to stone and raked out
Back wall tanking (tank up to 1m from floor): 12mm s&c renderwith SBR; 2mm Newton 107F brushed on
Back wall above tanking: 15mm Limelite renovating plaster scratch coat; use mesh at joint with tanking
Back wall to finish: Limelite Easy bond; 10mm Limelite renovating plaster; Limelite high impact finish
Other walls (no tanking): 15mm Limelite renovating plaster scratch coat; 10mm Limelite renovating plaster second coat; Limelite high impact finish
What would you do?
martinemj
I would fill any holes or dub out with an nhl lime mix
Sc if you wish where your tanking ...
Rest of it
Scratch coat limelite
2nd coat limelite over tanking too...
Finish limelite high impact
It's lovely stuff to use but God is it expensive
Bought some recently 21.00 bag plus vat
JML
Insulated dry lining system for walls. Ensuring external ground level is at least 150mm below floor level. What is the floor make-up?.
Groove37
What would you do?
@Ritch
JML
he as said its 600mm below g/l
Interested to establish the height of the external ground level in relation to the floor level. To state back wall is 600mm below ground is not giving that information. As the mention of tanking by the OP may suggest high ground levels, lateral and or penetrating damp issues.
ajn9000
FFL is 600mm below external GL - slab on ground is 200mm below that. The wall is 600mm thick: solid stone (slate), 400 years old. Already have a chemical DPM, so tanking is to eliminate any residual lateral/penetrating damp. Floor make up: 100mm concrete, DPM, 100mm insulation, 500g polythene, UFH, 50mm wet screed, decoupling membrane, slate tiles.
JML
Ideally l think you should if possiably to reduce the ground level and install a land drainage system to prevent dampness. The problem that l have experienced in the past with using s&c and tanking in this situation is that it will slow down/ prevent evaporation and can cause a chimney effect in that the damp will rise further within the structure in a bid to evaporate. Hope this helps.
tapit
say again?
martinemj
Jml is right
Best way to deal with damp in old houses is to do as much as possible to reduce the moisture against wall if you can
Also look at pointing ,guttering and renders in poor condition
some kind of drainage would help the situation or by removing the soil to below internal floor by say 6 to 12 "(french drain)
Not always possible....though
Dr martin says....Treat the cause if you can and not the symptom
ajn9000
External: will be installing a delta membrane into a land drain, as you describe JML
For internal plastering: I'm so far down to 2 options: i) original plan (Limelite), or ii) insulated dry lining system. I'd like the walls to breath as much as possible so i) seems to be the best option. I'm wondering whether to reduce the height of the tanking to minimise chimney effect / maximise evaporation.
Any other suggestions for internal plastering?
JML
Personally l would ditch the tanking as it prevents evaporation, you can also get water vapour passing through plaster and condensing on the face of tanking.
