Mate I did this last year on someone else’s job it was ok but after I just thought should of just used the ocr as a scratch coat instead as I enjoy using that materialGot a bungalow to price for render. Thinking of scratching in normal s and c . And top coat in ocr. To get even finish. Wot do you think. Never used it.
Agree better off sticking to one system whatever it may be bWhat wrong with s/c all the way through... don’t understand the question
Can't you get a nice even finish with sand and cement? If not why not?Got a bungalow to price for render. Thinking of scratching in normal s and c . And top coat in ocr. To get even finish. Wot do you think. Never used it.
You've got the mighty ritmo m,Mate I did this last year on someone else’s job it was ok but after I just thought should of just used the ocr as a scratch coat instead as I enjoy using that material
I set at 250 mate , have run it at 200 before but Tbf was to stiffYou've got the mighty ritmo m,
What water setting are you running for
Pral m, mate
Cheers mateI set at 250 mate , have run it at 200 before but Tbf was to stiff
Agree mate good luck with it are you spraying it now for an overnight?Cheers mate
I was trying to run it at 200 wanted it to pull in quicker, it must be pulling too many amps keeps tripping
I've got two plots to do with detached garages, I've been beading up and masking finished early so I've had a blast on the garage to get settings right it's going to be overnight mateAgree mate good luck with it are you spraying it now for an overnight?
K mix is nice to use.Got a bungalow to price for render. Thinking of scratching in normal s and c . And top coat in ocr. To get even finish. Wot do you think. Never used it.
Did you sort out the electrocution problem?Cheers mate
Yes mate marigolds seem to have done the trick for nowDid you sort out the electrocution problem?
