Removing plaster splashes
longy2010
Recently had a plasterer to plaster my living room ceiling. There are a few plaster splashes on my wallpaper and was wondering if you could give any tips on how to remove...
If your wallpaper has a shiny/gloss surface use a cleaner with hot water as mentioned above, but the cleaner needs citrus/lemon in it. Or u cud squeeze a lemon in warm water. It really helps. If there are large lumps, carefully pick them off with some kind of blade, but only attack the plaster, not the wall. Then remove as before.
