Refina stx410
Smurth1984
Hi all
My mates machine what we used today took ages to get the gear on the walls & ceilings also found that the gear was starting to go off in hopper.
Deffo quicker by hawk and trowel any ideas how to over come this.
Was mixing 30lt a time sparying multi finish
Hi all
Get a "mans" hardboard 16" and trowel to suit and blast some heavy rock plenty of brews and it's all happy days
Hi all
Thistle spray instead of multi or even knauf skim coat
Hi all
Did you clean machine out ok after using it ? No blockages?
Umm hard to say we started spraying at 8ish and it took an hour to put around 46m2 on wish i cud off put on my trowel a look quicker
• STX410 Spray Pump 0.75kw
• Hopper feed screw pump
• Will run off domestic supply & 3kva transformers
• Pump fitted with 2" diameter stator
• Machine weight 25kg
• Size WxL 50x75cm
• Height 75cm
• Hopper tank 30 ltr
• Pump output 4 ltr
• Noise level 59dBA
• Air required for spray gun 280 ltr/min @ 4 bar
• Size WxL 50x75cm
• Height 75cm
• Pump output 4 ltr
• Noise level 59dBA
That's a slower machine then the one in the video I reckon. 0.75 kW is small motor.
