refina s*p*r*lex trowel
leebo02
hi lads, anyone tried the refina s*p*r*lex skimming trowels, if so what do you think of them
leebo02
hi john, i am just trying one of the refina s*p*r*lex trowels at the moment,,bur artef using marshaltown trowels for so long i cant work out if i like it or not
jamesthefirst
I've got 2 that I've used for a couple of years now and have been really pleased. Well made but maybe a bit heavy and I have gone back to finishing with my marshalltown 14 inch after the initial laying on and flattening with the 16 inch refina.I found that the refina is an excellent ready to go trowel especially for beginners and better than the Tyzak ready to go which I threw away.
leebo02
cheers john,, think i will give it a little longer before i make my mind up,,,have tried a couple of different trowels in the past but its seems the marshalltowns are hard to beat and we allways seem to go back to them
johniosaif
Same here.
scottie5
I love these trowels mate, lay in, quick flatten with s/steel m/town then straight on it with the s*p*r*lex keep it at a real shallow angle and no water at all a couple of passes and your finish will be spot on. They are very delicate though, if dropped they bend not bounce.
windy
As above. I use mine same as scottie . Ss first. Then refina then plastic to finish.
windy
Only when I have it with me
usually it's just the ss then plastic to finish
was just trying to answer the lads question as I find the Refina blade a little thin and flimsy
jamesthefirst
At the last count I've got 16 trowels in the van and find flexible scrapers of different sizes usefull too.
plasterjfe
Give the Kraft Elite Trowels a go
I have a kraft there got the 11 inch just to see its like a gold blade with an orange handle. nice little trowel and would deffo now consider a 13 or 14 for plastering with if my marshall ever broke down
windy
I have the 14. Use it to trowel up then give it one last blast with the plastic. Hardly ever use the water sprayer any more. Just brush in the angles to tidy them up.
huddslee
gunna take some getting used to i think. its easier to leave ribbed marks in plaster if not carefull. but its easier on the joints and arms, but for now . those speed skims are ok tho u tried them yet????
leebo02
hi , never tried a speed skim,, i might try one soon
Darrenmkn
I have been using the s*p*r*lex trowels for about 1 year now and find its alot easier to use, The only thing with them they lose their shape aftter abut 4/5 months of use.. Does anyone know of similar trowels that last longer?
jamesthefirst
What do you think to the weight and their handle? I would like to change the handle to a wooden one.
scottie5
I changed the handle for a bass wood m/town handle off an old trowel, the shank is a different shape so had to pare it down a little with a small chisel to make it fit.
then stuck a Washer on before putting the old nut back on.
jamesthefirst
Thanks Scottie, I'm not very imaginative.:RpS_blink:
jeffplast
I've used one of these for around 4-5 years, I can't fault it. It's never lost it's shape, just look after it well and it'll last years.
