reducing graft and elbow greece
hello lads. skimmed a huge ceiling Monday over artex..1st coat on, set down, set down again, another coat set that down trowel. trowel again and a dry trowel...my shoulder is goosed!! thinking one of these speed skims or refina spatulas on a pole could save a bit of graft and trowel work. which would you lads recommend, do you think 600mm would be too small on a pole?
pointless getting the 600 for large areas get the 1200 its a good size for most areas you can get a 600 aswell for those smaller areas if you want
Hi mate,
Give us a all of your looking for one o the spats. We have a range of Excaliburs which are the same as the s*p*r*lex and we also do the EZE Spat which is a fraction of the price and has replaceable blades. We also stock a wide range of spspeedskims
I can also give you a discount as your a member of TPF
Ryan
They should be in for Monday. I'm with the manufacturers at the moment and they said they have left. This snow may cause some delays though! Will keep you informed
