rootytoottoot
I'm in NE Surrey looking for advice on options for re-rendering a gable end wall on a Victorian semi-detached bought recently.
There are signs of penetrating damp on both ground floor and 1st floor, plus an old attempt at chemical DPC.
The render is likely sand & cement. It seems to be well adhered to the wall, but is cracked and has been patched up in multiple places. The render also goes all the way to ground level, with no plinth.
Two different plasterers have both recommended hacking off old render and replacing with a cement and sand mix. A third plasterer has advised monocouche over the original render. It's been impossible to get a plasterer with lime render experience to even visit to quote.
Could anyone here advise how to go about selecting the best approach?
Also, what is the most suitable option at ground level (e.g. plinth, bellmouth, french drain, gravel trench)?
I'm finding it difficult to weigh up the different options due to the sheer volume of sometimes conflicting opinions/information out there.
Pics below:
External render - internal wall plaster has damp patches above the black strip, rising as high as 30 cm.
Cracks in render - 1st floor internal plaster is damp above the black pipe
Pics below:
