putzknecht s44 troubles
Albertnobacon
I wonder If anyone can help, Im using weber pral m and while spraying I'm getting a miss in materials also the material is coming out airy ( looks like an areo chocolate bar!) So when I rub I'm getting loads of little air pockets. Have tried all the basic stuff and no joy, any help would be appreciated.
I'm no expert with mixing pumps but it sounds like a problem with your mixing chamber ie bridging issues , how many water inlets on the mixing chamber ? Go wallcreting no problems then :cool:
Sent from my HTC Sensation XL with Beats Audio X315e using The Plasterers Forum mobile app
Nothing wrong with the pump your just not doing in two passes stop trying to do in one
We have the same machine...
Have you run a pressure test on the rotar and stator?
What water setting you running it on?
I thought mixing chamber but can't figure what, it has one inLet,Material is fine, never had a problem spraying in one pass and be spraying awhile, stator is fine that what I thought first, water setting is about 3.5 which I must admit I use to have it around 5 so I think this is a contributing factor.
