yeah u can, but its all down to the right mix depending on what sand ur using. what ever sand ur using u need to get a seive report that will help u to get the best mix
Lime will help with making the mix pumpable.
CPI gpm is not much more expensive and anyone can fling it in the mixer or machine.
Site mix must be used straight away as it starts to set quickly. You have to keep the mix constantly moving through the pump.
