Pressure tap
Ianspreader
Hello is there a pressure tap to check wear of rotar and stator that will fit a g5 and a ritmo? Thanks for
your help
no, you need a clamp then the rot/stat. put em together. put them in the clamp just nipped up so it dont fall through the clamp. then do a pressure test. you wanna see it at least 20 bar running and holding on min 12 bar. if you have higher readings loosen the clamp or tighten if you have low readings. check every day
