Who knew. ...rugby and owls were a couple.![]()
I'm not familiar with it.Hi
Has anyone had any experience with polymer and GRC with a wethertex resin coating does it provide a finish like Krend or similar?
Pros and cons advice would be appreciated.
Hi dimuc I use the system your on about the grc render is a flat rendered finish then the top coat is Wethertex which is sprayed on then the finish is similar to k tend but the texture and is sitting out from the wall as a it’s the k tend texture is indented in to surfaceHi
