Plastic trowel plastic???
Jim85
Anyone know what kind of plastic they use to make the blades on the plastic trowels? Eg the plaziflex?
There is a thread on here from last year that has exactly what type of plastic it is but cannot remember the name.
@Jim85
attachment.php
i found this list of plastics for you
A chair made with a polypropylene seat​
  • Polyester (PES) – Fibers, textiles.
  • Polyethylene terephthalate (PET) – Carbonated drinks bottles, peanut butter jars, plastic film, microwavable packaging.
  • Polyethylene (PE) – Wide range of inexpensive uses including supermarket bags, plastic bottles.
  • High-density polyethylene (HDPE) – Detergent bottles, milk jugs, and molded plastic cases.
  • Polyvinyl chloride (PVC) – Plumbing pipes and guttering, shower curtains, window frames, flooring.
  • Polyvinylidene chloride (PVDC) (Saran) – Food packaging.
  • Low-density polyethylene (LDPE) – Outdoor furniture, siding, floor tiles, shower curtains, clamshell packaging.
  • Polypropylene (PP) – Bottle caps, drinking straws, yogurt containers, appliances, car fenders (bumpers), plastic pressure pipe systems.
  • Polystyrene (PS) – Packaging foam/"peanuts", food containers, plastic tableware, disposable cups, plates, cutlery, CD and cassette boxes.
  • High impact polystyrene (HIPS) -: Refrigerator liners, food packaging, vending cups.
  • Polyamides (PA) (Nylons) – Fibers, toothbrush bristles, tubing, fishing line, low strength machine parts: under-the-hood car engine parts or gun frames.
  • Acrylonitrile butadiene styrene (ABS) – Electronic equipment cases (e.g., computer monitors, printers, keyboards), drainage pipe.
  • Polyethylene/Acrylonitrile Butadiene Styrene (PE/ABS) – A slippery blend of PE and ABS used in low-duty dry bearings.
  • Polycarbonate (PC) – Compact discs, eyeglasses, riot shields, security windows, traffic lights, lenses.
  • Polycarbonate/Acrylonitrile Butadiene Styrene (PC/ABS) – A blend of PC and ABS that creates a stronger plastic. Used in car interior and exterior parts, and mobile phone bodies.
  • Polyurethanes (PU) – Cushioning foams, thermal insulation foams, surface coatings, printing rollers (Currently 6th or 7th most commonly used plastic material, for instance the most commonly used plastic in cars).
[h=2]Special purpose plastics[/h]
  • Maleimide/Bismaleimide Used in high temperature composite materials.
  • Melamine formaldehyde (MF) – One of the aminoplasts, and used as a multi-colorable alternative to phenolics, for instance in moldings (e.g., break-resistance alternatives to ceramic cups, plates and bowls for children) and the decorated top surface layer of the paper laminates (e.g., Formica).
  • Plastarch material – Biodegradable and heat resistant, thermoplastic composed of modified corn starch.
  • Phenolics (PF) or (phenol formaldehydes) – High modulus, relatively heat resistant, and excellent fire resistant polymer. Used for insulating parts in electrical fixtures, paper laminated products (e.g., Formica), thermally insulation foams. It is a thermosetting plastic, with the familiar trade name Bakelite, that can be molded by heat and pressure when mixed with a filler-like wood flour or can be cast in its unfilled liquid form or cast as foam (e.g., Oasis). Problems include the probability of moldings naturally being dark colors (red, green, brown), and as thermoset it is difficult to recycle.
  • Polyepoxide (Epoxy) Used as an adhesive, potting agent for electrical components, and matrix for composite materials with hardeners including amine, amide, and Boron Trifluoride.
  • Polyetheretherketone (PEEK) – Strong, chemical- and heat-resistant thermoplastic, biocompatibility allows for use in medical implant applications, aerospace moldings. One of the most expensive commercial polymers.
  • Polyetherimide (PEI) (Ultem) – A high temperature, chemically stable polymer that does not crystallize.
  • Polyimide—A High temperature plastic used in materials such as Kapton tape.
  • Polylactic acid (PLA) – A biodegradable, thermoplastic found converted into a variety of aliphatic polyesters derived from lactic acid which in turn can be made by fermentation of various agricultural products such as corn starch, once made from dairy products.
  • Polymethyl methacrylate (PMMA) – Contact lenses (of the original "hard" variety), glazing (best known in this form by its various trade names around the world; e.g., Perspex, Oroglas, Plexiglas), aglets, fluorescent light diffusers, rear light covers for vehicles. It forms the basis of artistic and commercial acrylic paints when suspended in water with the use of other agents.
  • Polytetrafluoroethylene (PTFE) – Heat-resistant, low-friction coatings, used in things like non-stick surfaces for frying pans, plumber's tape and water slides. It is more commonly known as Teflon.
  • Urea-formaldehyde (UF) – One of the aminoplasts and used as a multi-colorable alternative to phenolics. Used as a wood adhesive (for plywood, chipboard, hardboard) and electrical switch housings.
  • Furan—Resin based on Furfuryl Alcohol used in foundry sands and biologically derived composites.
  • Silicone—Heat resistant resin used mainly as a sealant but also used for high temperature cooking utensils and as a base resin for industrial paints.
  • Polysulfone—High temerpature melt processable resin used in membranes, filtration media, water heater dip tubes and other high temperature applications.
well why do you want to know, jim. some things are best left alone. if you do make one will it work if it's not black?
No I don't know much about plastic. I'm a plasterer. I just wanted to know if anyone knows what kind of plastic they use on the trowels. Not what sort of plastic they use for everything made of plastic
If I know what it's called I can buy some. Whoever I buy it from isn't going to ask for my qualification in plastic
Save 20 quid every time I want a new blade. Make new sizes to try without forking out for something that mite not work. Calm down jurek there's more to life then tpf
phone the refina helpline, jim. say youre thinking of buying one. what kind of plastic are they? are they the same as texturing trowel etc.
