plastering over tiles
pmac
can i just use pva with sand, a tight coat of bonding and then skim? or should i buy the expensive stuff (cant think of the name of it)
dont think that pva and sand will have the same effect as bonding agent i would be safe and do it proper.. ;)
Yeah go for the bond-it or wickes stuff. If your gonna have a go with out it i wouldnt bother with the pva as it wont do alot for that situation, and would be a waste of pva. You could use a SBR sand and cement slurry, and splatter coat that would give you a good key to bond over.
if you do use gypbond or sbr slurry and if you can tie it in i'd be tempted to thistle bonding one day and skim it the next, you get absolutely no suction at all chuck a bit of dirty water in with the bonding to help you get a float on it
