No foil either side, the insulation board has a glass fiber face both sides. One side bonded to wall with expanded urethane foam to eliminate any air gap (can explain reasoning behind that if wanted, but gets sort of long). No plasterboard, the glass fiber backing mat is bonded to the insulation much better than plasterboard normally is. The board was recommended by one of the technical guys at Kingspan as the best way to go for direct rendering / plastering on, but another of their technical guys didn't know what internal plaster to use. Since it is low suction I think standard bonding should do. Just wondering if anyone else has used anything like it. Celotex make a similar board.
Yes, new.
