Plastering Lines!
electronurd
Hi all,
I'm a DIY'er and yes I know I probably should have hired a plasterer... but i've fallen on tough times so i'm here for a bit of help please. My dad was a plasterer but has passed so I can't ask him.
Last week I plastered my fireplace. I didn't plaster the whole thing, I only plastered half of it as we opened up our fireplace.
I placed a bonding coat onto bare brick first and then skimmed on top of the bonding coat. I spent what felt like what a long time trying to smooth out the finish the best I could. Felt ages.... the girlfriend came home and said "wow not bad considering you are not a plasterer".... but I knew something wasn't right and waited for it to dry...
Now that it has dried there are quite a few lines in the plaster and I am wondering how to remove them please (see pictures)
Any help to correct this would be much appreciated.
K
Keegan88
Guest
Hmm that's not good, like at all, but I'm sure you know that. Erm, I'd probably recommend giving it a mist coat of paint (watered down paint) then buying a bag of easi fill, filling it all and then sanding the hell out of it. You could get a plasterer to skim it for around £100 I'd say if you got a few quotes and took the lowest, but up to you
K
Keegan88
Guest
ok thanks. How would i not get the lines though if I plastered again? is there a timing to this sort of thing?
Well firstly you're probably using a very cheap trowel, secondly you've probably tried to get it far to smooth to soon, it's not meant to look perfect for around 2.5-3 hours after you start. Get it on the wall, trowel over to make it reasonable then leave it until it's firmed up slightly, quick trowel over and then mix up a second coat and do the same again. That might will take you to about 2 hours, then leave it to firm up, spray a small amount of water on it and trowel again. Then wait a little while and dry trowel over it. There's some decent videos on YouTube to show you the basics
electronurd
Thanks for that. If I use easifill over the top of this will I find it hard for it to blend into the excisting wall? or is there a trick to that. Also how think should I apply the easifill? like very thin?
stuart23
Use sandpaper first, give it a right good rub down and get it as flat as possible. Mix up your easy fill then fill all the holes. Run your fingers over it and anything you can feel fill with the filler. Rub down again and repeat till your happy.
choppa
Hi all,
Take the knock and get a plasterer to skim it. Won’t be a massive wedge of money. More hassle fixing it
Stevieo
Royal Spin Doctor
Hi all,
So that didn't turn turn out like you hoped.
Better luck next time
Plastering not so easy after all, eh?
32582
Simon85
Get a professional in to sort it ideally. If not sand all the ridges/lines out etc and as said easi fill to there is no more holes.
Why do DIY groups assume and encourage ppl to have a go at plastering though? (not aimed at poster, it's a general wondering)
They wouldn't recommend trussing a roof, or wiring or plumbing the house as a novice why do the assume our trade is fair game for the have a go hero's.
Djr
Personally I would get a plasterer to 're _skim it rather than spend hours filling and rubbing down . As choppa said won't cost the earth that
djfleming22
I didn't expect it to be... it is a DIY'er sub-forum however and people can have a go. But thank you for your positive feedback, advice and support [insert sarcastic tone].
Honestly just get a plasterer all that rubbing down fuckin dust everywhere for days ...get somebody in and they should make it look easy
Ritch
Hi all,
It will settle
Danny
Administrator
I would just sand it and get filler on it and keep going till you are happy.
Its not thend of the world and modern day fillers are great
electronurd
Hi yeah thats the plan thanks. I have sanded it down and to be honest it's not bad at all but still going to use a filler on it, the sanding took no time at all. I've also purchased a new trowel as the one I was using was a very cheap one. I bought a tyzack trowel on someones recommendation. It has a few scratches though on the trowel face... is that normal?
John j
Mono Don
You want a mediflex mate awesome trowel . Can get you one at a good price as well
electronurd
Damn it's a bit late... i just got this one and paid the same price as a mediflex too... but i'm not a plasterer so i'll stick with this one and see how I get on. Thanks for the recommendation though
Stevieo
Royal Spin Doctor
I just use a bnq trowel.
Don't listen to this lot.
Gavine The First
