Hi all,
I’m trying to dot and dab around window reveals and under the (very long) lintel - reveals are ok but the plasterboard under the lintel falls off. I can’t reinforce it with screws as the metal of the lintel is really thick. Any ideas please?
Rachel
Ffs mate ! Your foam mad !!!Or foamand props
When are you two to tying the knot ? Its long overdue mate .Only poor people are mad.
@ChrispyUK is eccentric.
Cock wipes more like ! FfsJust down to scheduling mate. Pauly is busy with ‘next level’, I’m busy with CHD.
Just releasing a new range of CHD hand wipes if you’re interested?
I'm not touching anything that's been anywhere near you mate, send it to casper though, he needs a little bit of kindness .Should be ok for that mate. I’ll send you some, let me know if they work ok![]()
Can I be you two's worst man mate ? It would be a real honour !Just down to scheduling mate. Pauly is busy with ‘next level’, I’m busy with CHD.
Try having a sense of humour mate .Try wine mate, but more forgiving than Stella![]()
Wine is pish anyway !Try wine mate, but more forgiving than Stella![]()
Try having a sense of humour mateTry wine mate, but more forgiving than Stella![]()
Try having a sense of humour mate![]()
That's the spirit.We’ll get there mate. I haven’t given up on you
That's the spirit.
You have the wisdom of Solomon.Ideally you get this on first. You could cut a bit of wood same length to support it with a few props underneath or just some off cuts of plaster board cut slightly longer and wedged in at an angle till it goes off a bit.
The choice is yours. You have as long as it takes for the board to revolve.
No he hasn't!You have the wisdom of Solomon.
The OP should listen to you.
I’m trying Pauly. Running out of Vaseline and cock wipes, Please come soon x
In vino veritasVery good. See, vino is the future![]()
Curtains were used as cock wipes in my day,Cock wipes more like ! Ffs
