Have u got a linkI know I had to google them.The sparks put them on the plasterboard(there stickyback plastic)where there lights are going we skim over them and when the plaster is dry they show through and the spark cuts his holes.Simple but brilliant
YepAre they small enough to put where the radiator bracket screws go?
Im going to buy some them...would be great if you could remove the radiator screws and have a clean run
Is that without the dots? good ideaIf you screw the screws right into the wall take a rough measurement then skim over as normal then use a magnet to locate them, then screw then back out the wall?
No dots, just a rough measure so you know the general area then once it's set run magnet over the wall and find the screws. Job done!
You should post this in the top tips thread as its a feckin top tip mateMost of the time I don't measure I just mark the floor in line with them then run the magnet up from that - abit quicker than way!
You should post this in the top tips thread as its a feckin top tip mate![]()
They can't movehttps://plasterspot.com
They've been around for a while now.
They good except I was on a job recently and the spark had cut a load of holes out as a couple of them had been moved by the plaster when spreading apparently. [emoji43][emoji43]
Wasnt it @scottie5? When you do monster guages like him suppose last thing you need is going round rad screws. I just take them out +keep popping the holes through again once gone over it. [emoji1303]Didn't someone share a tip about using a piece of straw pushed into hole, skim over doesn't hurt your trool, jobs a goodun. Might of been the voluptuous @beddy , not sure
Cost a packet these little dots of tape?
They are expensive for what they are, but at least they do exactly what they're intended for very well. Unlike some stupid ideas people come up with. (I'm still pretending you're real see)£7 for 25 dots and they don't hold a thing up? clever though.
