Plaster v Plasterboard
Arvski
Hi,
First time poster here in need of some steer. I'm renovating an old victorian property. The areas I need "plastered" are (3.2m high ceilings btw):
1. Party wall in terrible condition. Half of the wall (neighbours side) is a staircase but the other half is a bedroom. I'll have my kitchen up against the bedroom which will help but I'm keen on soundproofing as much as possible - skimmed soundproof plasterboard?
2. New internal block walls, including one that the TV will be hung on - plaster?
3. Chimney breasts - plaster?
4. Ceilings, soundproof plasterboard?
The plasterers that have come around to take a look have suggested dot/dab or battened plasterboard as it will be cheaper material and labour.
I prefer the solid feel of plastered walls, especially for hanging TV/Speakers etc, and am not a fan of the hollow cavity sound.
Although I'd like to keep costs down as much as possible I'm not convinced by the plasterboard alone and think I may need to mix methods at a minimum?
I'd be grateful for any advice.
  • Plaster v Plasterboard
stairs wall will need float n set, you'll struggle to board that wall without coming over stringer.....your 'plasterer' should've advised that he obviously hasn't a clue get a different spread in...I'd Hardwall it at the very minimum but depending on budget I'd prefer limelite renovating system but finding a spread willing and able to do that properly nowadays might be a challenge be careful you don't employ a chancing 5 min facebook skimmer trades full of em
Hi,
Solid plastering is a dying art, if that’s what you want then don’t employ anybody aged below 45yrs old because they won’t have a scooby!!
All the best with it all.
just to add: sparks not done you any favours with first fix on stairs wall either
Thank you, my gut was saying traditional plaster but got caught in two minds when considering sound proofing.
you don't really have much of a choice but to float & set it I'm afraid, to soundproof that wall with boards you'll have to come way over existing stringer.....dot n dab soundbloc will virtually have no effect. As someone else has mentioned, soundbloc is only really effective if installed correctly.
If you go down that route, you could make a new false stringer I suppose but you'll be narrowing the stairs quite considerably.....it won't be just one or two inches and your big old Victorian house will end up with a terraced staircase and look utterly shyte.
Someone told me 12.5mm plasterboard has a lot more properties thermal acoustic etc than 15mm sand cement, it’s hard to believe nowadays so many new systems and no jobs the same?
Same job different spec
