Yes , tbf there’s quite a skill though to do this , just worth bearing in mind if never plastered before mateHi, I have artex ceilings throughout, the fan type about 1-2mm thickness for the ridges. Can I just use multifinish plaster to cover this up and create a flat ceiling? Thanks
If possible I overboard artex ceilingsHi, I have artex ceilings throughout, the fan type about 1-2mm thickness for the ridges. Can I just use multifinish plaster to cover this up and create a flat ceiling? Thanks
How old is your house? If it’s 80s/90s then yeah you could skim over it adding a couple handfuls of bonding in the first coat. If it’s an older property then overboard and skim
Because if the property is old lath then chances are they’re already coming away from the joists in places and by skimming over you’re just adding more weight. Cracks will probably appear because not all will be visible to the eye to tape. So all round it’s a better, safer job for longevityY overboard x
Yeah you do to be fair. I judge what I’m doing on the age of the gaff and always give it a poke to see if it’s spongeyFair point me lady, could be wrong but find that swirl on post lath properies usually
Tellum Jess.Because if the property is old lath then chances are they’re already coming away from the joists in places and by skimming over you’re just adding more weight. Cracks will probably appear because not all will be visible to the eye to tape. So all round it’s a better, safer job for longevity
Always..... we all know I make the rules round these ‘ere parts!Tellum Jess.
Arguing with me is futile! Death to all who dare!Well there's no arguing with that is there?
Wsssht.Arguing with me is futile! Death to all who dare!
No it isn't.Arguing with me is futile! Death to all who dare!
No it isn't.
