S a plastering
After a 14 inch new trowel was lookin at the permashape but they used to have a slight bend in tye blade popped a rivet on mine so need a new one decent 14 inch stainless cheers
What’s it for?After a 14 inch new trowel was lookin at the permashape but they used to have a slight bend in tye blade popped a rivet on mine so need a new one decent 14 inch stainless cheers
After stainless realy tried all that fannying around to much looking after the fcuker
What’s it for?
If it’s for skimming get a carbon.
Get the 14x4 3/4 they are usually the flattest trowel with a slight flick on each corner. Keep their shape to. Them permashape are terrible, had them warp once they’re broken in.After stainless realy tried all that fannying around to much looking after the fcuker
I got a stainless nella in van. 13 inch seems a good trowelAfter stainless realy tried all that fannying around to much looking after the fcuker
there shite aswell
worse trowel on the market for skimmingGet the 14x4 3/4 they are usually the flattest trowel with a slight flick on each corner. Keep their shape to. Them permashape are terrible, had them warp once they’re broken in.
Love mine but still not worn inI got a stainless nella in van. 13 inch seems a good trowel
I use nella carbon. But fed up of love they need . The ss feels just same thiughLove mine but still not worn in
Troed them my mate found them a big stiff take ages to break in not a loverI got a stainless nella in van. 13 inch seems a good trowel
What trowel you use algee?worse trowel on the market for skimming
decent for floating holds the gear well
They are but worth it in endTroed them my mate found them a big stiff take ages to break in not a lover
Really you lay on with a s*p*r*lex mate?nefer thought of that do you flatten inbetween coats with it aswellI use flex all the way through now for skimming mate
an 18" ox well broke is unbelievable how flat it keeps it
and a touch of 18"medi in between..
Haha know what you mean each to there ownFlatten between coats!!!!
Mate where have you been for last 10 years @algeeman wouldnt be plastering if he had to put a 2nd coat on!
