View attachment 32262Here’s a photo so it makes more sense, where the blue string is is where the end of patio wil be
Anything I’ve got handy, rubble, roughcast chips and that. Obviously once I get near the top I’ll need to use proper stuff.I've built conservatory bases (solid base) single skin, but probably not quite that high.
What do you plan to fill the base with?
Decking would be better imo mate
Omg well spotted mateThe Strata thrown to one side like a wheelie bin![]()
That’s an old one used for spares, the other one is under wrapsOmg well spotted mate
Wtf he doesn’t care anymore
Would you lay the blocks on there side for more strength?Rubble will sit on itself best without wanting to spread. If you want belt and braces, use a bit of concrete round the edges. I'd probably lay my slabs on concrete with what I think you're building too.
Going to try fill it with as much rubble and other stuff as I can then when get near the top go down the hardcore route with whacked plate. It’s going to be a big patio as it’s going in an L shape so trying to save as much cash as I can.Block on flat be best, measure down from sill, thickness of bedded slabs and blocks so bottom course of block is few inches below ground level then min 6" concrete down to bottom of footing.
Fill up hard core whacked tight in 6" layers and top with whacked type 1 hard core to dust. And slab away with 1.5" overhang on blocks.
Fk thatHe could get a cat ?
He's not building a skyscraper.Block on flat be best, measure down from sill, thickness of bedded slabs and blocks so bottom course of block is few inches below ground level then min 6" concrete down to bottom of footing.
So pour concrete down every corner for strength?He's not building a skyscraper.
No, not if you're filling with rubble and putting on a slab. Rubble won't put much pressure on the wall.
Like I say, cheapest solution would be to stay back a bit from the wall and infill concrete - be solid as fook.
Basically, chuck in a pile of rubble, fill the corners up with concrete, blind it off with hardcore, whack a slab on and tile it.
Bada bing.
Aye it’s a lotIf you don't pack your rubble right up to the wall, fill the void with concrete - or least some/most of it. Be a lot easier than block flat. What's block flat...4x more block than regular laying? It's a fuckign lot of blocks.
Don’t like decking, had it in my last few houses and don’t want it in this one. Getting slabs similar in colour to the large tiles in my kitchen so that when the doors fully open it looks like one large area.Decking is eco friendly and loads cheaper too
