It's a knack mate.Anyone have any tips on patching thin coat spraying? If you tape it off won't it leave a line and if you spray the patch won't the surrounding area build up more then the rest. Just seeing if anyone has any ways?
Tia
I was thinking of cutting a piece of cardboard the shape of the patch and build it up that way then once it's built up gently spray the edge?It's a knack mate.
Do a test board and blend into surroundings.
Done a few through damage, once you have your settings and understand distance, angle, power (flow) and speed of movement - should be unnoticeable.
