I'm knocking off s&c render on a garage ready to parex monocouche, but there are random thermalite bock a all over the place, I've never put it over therms before so wondered the best method ? Cheers all
I would check with your Parex rep but I'm guessing they will say micro gobetis the whole wall first to give a good key and even suction. Then they might ask you to put TV10 mesh over the random block areas to avoid cracking if there is any differential movement.
