Parex maite.
Swplastering
I’m currently doing a thin coat job at the moment I am using Parex maite with a 0.5mm top coat. I will be spraying the top coat so the base coat will need to be spot on but maite isn’t the best to get to a nice flat finish. Any ideas. Thanks.
Rossi46
If you’re using 0.5mm to finish and need it perfect I’d be tempted to do the first base coat then go over it the day after with a tight skim and get it bang on. Spat it perfect.
