Paraguard/everbuild sealer
User___removed
Has anyone used the everbuild sealer.just finishing a monorex job and was going to use paraguard.the quants I need is around 1 and a half tubs.
I've had a quote for paraguard for 240 plus so at 500 I was thinking of using everbuild sealer @ around 60 for 25 litres.
Any feedback chaps?
Cheers
You might as well give the punter sand and cement if you want to leave them with absolutely no warranties.
Gotta admit paragaurd is expensive for what it is they prob get it for buttons too.
Do a sample Bob using everbuild and see how u go.
With paragaurd 1 coat will make a difference. 2 coats will last longer but eventually I expect it will break down.
Just like krend silicone really it works at first but after a year you can see the rain soak straight in. Paragaurd will be much higher in silicone content tho and will do a better job for longer.
