paper corners
easy fill mate...then easy fill for 1st coat then sanded or timed right and jumbo sponge then top with joint compound
I bed them with joint filler and coat over with the excess that comes out the sides, when dry, 2nd coat of joint filler, once thats dried a coat of joint cement and finally a light sand.. solid... joint filler is the red bag, I know they do the green bag that only needs two coats.. i prefer the first way though..
Joint cement to bed the tape and quick 'fill over' with excess then next day coat out again with joint cement, dry and then sand to a finish, joint filler and easi fill are ok but joint cement is softer so soaks in better to the paper, that's my experience anyway. Beehive doing it 26 years and no problems , good luck whatever you choose
