OCR in two passes
craigEEE
I've got some garden walls I'm doing, we've used MS-20 but didn't think it would dry enough to be done in 1 day so have done it as a scratch coat method
Anyone else do this and also does the base coat need to be fully dry before we 2nd coat?
Good idea . Yes the base coat needs to be dry . The suction will pull in your second coat nicely and rub up better . I’ve tried Ocr without a scratch coat and find it slumps .
We use Weber OCR as a two coat.
Have you ever gone onto Weber OCR scratch on a hot summers day...not recommended, did it once never again.
If you are 2 coating with Weber OCR...do it same day in 2 passes...or if leaving it put waterproofer in the scratch.
Or better still use Fassa KI7 no waterproofer needed and no micro cracking.
Personally I’d use Johnstone’s high performance render . Put a coat on , notch it , bed mesh in , top coat it next day and sponge float it flat as a witches tit . It’s mint gear . 10mm beads btw
We just dampen the scratch coat before topping in the summer.
Is that bricks ? If so might give it a go only really do sand and cement.
I push for Johnstone's gear on nearly all my work, unless the customer has a preference,
I think it's one of the best and priced well
Is it the base coat or one coat stuff? just been looking on there website.
Same stuff mate . They do a key coat primer (RendAid) but you only need that if the brick work is bad for example where you’ve chopped off old stuff . I did back of my house with it . Straight on no problems then I put silicone render on top but you don’t have you van just sponge it to plain Face if you want to
Even going over OCR on a cold day is a pig, it sucks like an amsterdam hooker.
