smedhead
[h=1]BOLIX Thin coat silicone textured render 1.5mm - white 30kg[/h]
Manufacturer: Bolix
Model: KA 1.5mm - 30kg
Delivery time: 2-3 days
Price: £87.60 £75.60 (inc VAT)
Qty:
OR
Add to Wish List
Add to Compare
Description Related Products (6)
[h=2]BOLIX Thin coat silicone textured render 1.5mm - white 30kg[/h]
Description:
BOLIX silicone is a decorative and protective thin-layer render to be used outside and inside of buildings, in EIFS (based on mineral-wool and on EPS) as well as on even and suitably prepared mineral substrates (such as concrete, cement-based plasters, and cement-lime plasters). It gives a durable, hydrophobic and steam-permeable layer of high elastomeric properties, resistant to dirt and weather conditions.
Coverage:
2.5 - 3.0 kg/m2
Substrate:
Substrate should be sound, even, dry, clear of anti-adhesive layers and microbiological and chemical contamination.All cavities of 5-15mm should be filled with Bolix-W and smoothed with Bolix-U adhesive (eventually Bolix-UZBdepending on weather factors). Cavities of less than 5mm can be filled directly with Bolix-U. The substrate should be primed with Bolix-OP (white as standard or colour matching to render). New substrates should be left for 3-4 weeks before applying acrylic render. Although product is supplied as ready mixed, directly before application it should be mixed with low-speed basketmixer to uniform consistency.
Application:
trowel-applied structural renders: spread evenly a thin layer of render on a substrate with a stainless steel flat float. Next, remove the excess of render with a short stainless steel float - render layer should have the thickness of the aggregate used in the render (you can reuse the removed render after remixing). To obtain a desired pattern, make the finish floating with a plastic flat float. Press it gently to the substrate and make regular movements on the whole wall surface. Finish floating depends on the type of render. To obtain a grout pattern make circular movements, woodworm pattern – horizontal or vertical movements, modified pattern – long semi-circular movements.
Note!
In the summer, to thin the mortar, you can add some water to structural plaster – max. 400 ml per 30 kg. Do not exceed the consistency of 12 cm on a measuring con.
Note!
Protect new layers from rain and temperatures below +5°c and above +25°c until set. Hardening time min. 24 hrs. In low temperature and high humidity or in low ventilation, the binding period given above may be longer. When applying avoid direct sun, rain and strong wind.
Storage: store in a tight and original, undamaged packaging in temperature between +5°c and +25°c.
Special Price Offer expires in: | 3 days, 4 hours, 30 minutes, 34 seconds |
Qty:
OR
Add to Wish List
Add to Compare
Description:
Coverage:
2.5 - 3.0 kg/m2
Substrate:
Application:
Note!
Note!
