Newbie Darby Question
drpah
Hi all,
I was browsing the web looking for info and found your site. It looks just the place to ask a question regarding a Darby. I see that there has been some discussion on the use of a Darby verses a rule. My plan is to replace some damaged plaster boards on an angled ceiling then skim over. I am very much a newbie in this area and would appreciate some help.
I have bought a 48â€￾ Darby assuming that it would be useful for checking for high and low areas and shifting the high bits. I will not mention the brand. The Darby is bowed, the centre is a few mm raised when placed on a flat surface (handle attachment side down) but only light force can bring it true. Is this to be expected? I would have thought that it should be flat and quite rigid.
Your collective views would be appreciated.
Darbys should be straight , egnore ryan he thinks a speedskim will do the same job lol although using a darby on finish isnt normally heard of ....
nothing wrong with straight darby, quite easy to use in small areas, must be straight, if interested I now use t bars in Australia they are a bit different to start with but work well, all about learning, cheers rugbymad
Hi Guys,
Thank you all for your responses.
I have not had the time to until now to get back to you.
It seems that, as in all trades, personal preference and experience goes a long way. The particular Darby will probably be retuned unused. As for a straight edge I kept the aluminium extrusions from our old shower cubical. They are light, straight and very rigid. So one will do the job fine.
Thanks again!
