Fine Interiors
Hi Guys
We are a Drylining firm who has recently been asked to do a bit of plastering. Please bear with me as i list the spec -----
CEMENT : SAND (AIR ENTRAINED) TO WET AREAS]
PREPERATION: Stipple Key
Undercoats: Mix 1:4-5 masonary cement: sand or 1:5-6 cement:sand (with air entraining admix)
Cement Type: Contractors choice
- Thickness (excluding dubbing out and keys) : 12mm
Final Coat: Mix: either 1:4-5 masonary cement:sand or 1:5-6 cement:sand with air entraining addmix
Thickness: 7mm
Finish: Plain
Now, in my limited knowlege this is 2 coat work? what sort of rates should i be paying plasterers? Based on VERY large areas. Ideally would like it sprayed on. This is just 1 of the specs i have. There are about 4 diferent specs. Wet/Dry areas. High impact etc
is there a bagged basecoat product that i can buy in? Or should i order sand + cement and mix on site?
Many thanks
Al
Thickness: 7mm
Finish: Plain
Many thanks
Al
