I have used them for years , plasterersonestopshop sell new mixers that are brilliant and much cheaper than Bosch, eibenstock, great people to deal with ,great for helping out plasterers down on there luck too,Bosch grw 11 e is the best drill out there
Not this all over again !!!??? The eibenstock has been going for years in Germany and the refina drill made in the same factory different handles and colour thats it !? Oh no forgot the refina is more expensive too!! The 1800w eibenstock is the dogs and had mine ages and whips couple of bags up perfect in less than a minute!! Or just get a nutribullet 900 instead and at least be healthy???
What's a negative paddle?Alfra eibenstock mixer on ebay. You can get the 1800w for £285 with a negative paddle if you message him
When I last bought a mixer i saw the Bosch at the time and didn't really give it a second look,it was a few years ago mind,have you used both Bosch and alfra/refina and as it doesn't have the wattage of the others does it put out the same mixing power?Agreed.
Galloping horses wouldn't pull me away from my Bosch though. [emoji173]️[emoji173]️[emoji3]
Do they only do the one model?il have a search on tinternetI've had 2 drills in 28yrs, both Bosch. 1st one got nicked, present one I've had since 2003. Replaced a few switches in them 28 yrs (1st one was 2nd hand) and a load of paddles. Hardwall, compound , multi etc. You can't do better than that
Ive used the 1800w refina, 1600 w belle and bosch and the bosch is a different beast. Not as comfortable as H handles on the refina etc but so much torque! Im in the market for a new mixer and would go for the bosch if it wasnt £150 more than the refina which I know is up to the all the jobs I'd use it for.If I remember right the turning torque on the bosch grw11e (£450ish) is over 100nm in the slow gear!
Not sure what the eibenstock is but every time I check it out on other rival drills nothing even comes close.
It would be interesting to know though if @Plasterers1StopShop has spec on the alfra?
Can the Refina handle plenty of stiff drywall mixes?I got one about 8 years ago for about 300 on eBay , I remember because I couldn't believe it was so cheap. As they were nearly 500 25 years ago!
That's the one. I threw away the Bosch paddle it came with and got a cullamix 160 one. Not sure if it's positive or negative one but when it mixes the drill rises out of the bucket meaning you push it back in as opposed to the other one which pulls the drill into the bucket which means you're straining to pull it up
