New eco marble white
Elite exteriors
New bag's?
Marble white bags now have purple on them they are different was spraying over some areas of G10 and some block today and it was sliding off of the G10 I couldn't rule it without it tearing and sliding off couldn't spat it without it tearing the surface was wanting to go but the underneath was soaking wet
Tramp
Sounds like to much Polymer
Elite exteriors
Some are saying they are messing about with the lime they put in it and that's why they had to change the bag
Of course that's a Chinese whisper and could be completely wrong
It was just weird I've never had anything like it happen before I ended up having to scrap it off
Tramp
Sounds like they've f***** about with the polymers, when you've got higher polymer concentrate, It closes the pores of the render, and doesn't set consistently throughout the material, instead creates a skin on the surface and holds in the moisture behind, hence tearing, It's also kills suction so when it hits a surface The suction won't be the same probably why it's sliding.
Elite exteriors
It was just about manageable over block but I couldn't definitely tell something was different what you're saying sounds about right though cheers
