tycho
Hi all, hoping to get a few answers here as I've been reading quite a lot of contradictory information on the net over the last while!
The house:
Any help would be much appriciated,
Cheers
The house:
- New build, single story
- Masonry (block-on-flat) + EWI
- no insulation or stud inside
- 150mm floor insulation on top of slab
- 70mm floating screed with UFH
- What would be the normal thickness for internal plastering? Ive read 15mm scratch coat + 4mm top coat?
- I was advised to put in a scratch coat before the floor insulation+screed goes in (to make the walls airtight right down to the slab), is this advisable?
- Is 70mm screed thick enough for UFH? Possible with sand and cement of liquid screed more suitable?
Cheers
